Scanner VHF antenna
NCFire11
Hello,
I am in the process of figuring out how I want to set up my scanner antenna. Right now I have a PRO197 with a RadioShack VHF collapse able antenna. This works ok however I think I can do better. I have both a 1/4 wave or a 5/8(I think because it has a loading coil) VHF antenna that I want to mount to the side of our house. Right now the scanner is really fuzzy I think is mostly because it is close to my computer equipment. Which antenna should I use? It will be receive only and I know having a ground plane is an issue but I don't have a clue how this stuff works. Another issue is multipath. Our county uses a simulcast VHF p25 system.
Any comments or ideas are appreciated.
NCFire11
also can this be used as a good way to extend my coax to my antenna?
http://m.e
bay.com/itm/330773684986?nav=SEARCH&sbk=1
