Scanner vs. Receive-Only HT
kf4sek
Cocoa, FL
What are the advantages of a GE M-PA handheld radio over the many scanners on the market? What are the disadvantages? I am looking at a GE M-PA for listening to the local EDACS 800-MHz Analog system (Brevard County, Florida) and was wondering if I would be wasting my money?
Thanks in advance.
mike_webb59
New Braunfels, TX
One of the disadvantages would be in programming. The EDACS programming software for that radio is basically impossible to get, whereas with a scanner it would be much easier to program.
I use MPA and MPD radios for conventional channel receive, as IMHO a purpose-designed radio should capture some frequencies that may get skipped by a scanner.
I would however, always try to use a scanner for EDACS systems.
Just my $.02
Mike
ctpd845
Martin, Ohio
You would be able to scan more talkgroups with a scanner over an M-PA. Plus as the prior post stated, it is almost impossible to get the programming software.
mancow
N.E. Kansas
Adavantage: DISTANCE
I can receive KCMO on an M-PA or M-RK when the scanners are nothing but noise.
