scanner won;t stop on tg
jlo
mount pearl, NL.
seems the my 396xt will not lock onto certain tg's
it will stop on the conventional ones but no the tg that are entered from the data base.
but hit the hold but and scroll through and bam. they are talking on it. but take it off hold and it will only lock back on the conventional one again.
is common with the 396t' or xt's not being able to lock onto these.
and any know way to fix it.
also what is the most current s/w for the 396xt.
or maybe these scanners just don't like edacs..
thx j
spencerville
go into program settings> your system you programmed >edit site> hold time see if its set to 2 seconds instead of 0 that might be the problem
torontokris
Toronto Canada
are all the group quick keys enabled? Try ID search instead of scan and see if you get anything
the 396XT handles EDADS just fine
if you can hear them in HOLD mode then it sounds like something is wrong with the trunking frequencies/setup/bandplan
if its a EDACS system, did u import 1 site at a time (with all frequencies) or mash them all together?
try one site at a time.
