scanner
hunter72163
I have a uniden BC246T scanner. It is not picking up my channels if i re band does that help? I have install arc246 to reprogram and nothing
iMONITOR
MACOMB, MI.
What state/county/city/township do you live in? Has your public safety services converted to one of the digital systems?
captclint
Mountaintop, PA
Please provide your county and state, and any specific agencies you are having trouble receiving. The 246 is a very old analog scanner, and may not receive much in your area.
jonwienke
More Info Coming Soon!
VA
Analog scanners aren't "junk", they are just limited to receiving analog traffic such as ham repeaters, GMRS, MURS, NOAA weather, etc. If you get a digital scanner, you can use it to monitor digital traffic, and still use your current scanner to monitor analog channels.
jonwienke
VA
Look at what they are selling for on eBay--probably not much. You may be better off keeping it to monitor analog traffic.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
For conventional traffic, see this page from our database...
https://www.radioreference.com/apps/db/?ctid=674
Note that anything that doesn't say DMR, NXDN or Telm (telemetry) is a possibility. Even as relatively flat as Springfield is (I was on a contract assignment there), the little antenna that comes with these scanners is very poor. A better antenna is definitely in order here.
It is also possible to modify that scanner to feed into a PC to decode the DMR or NXDN, but that's a topic for another day...Mike
iMONITOR
MACOMB, MI.
so if i have a analog its junk right
Have you considered monitoring aircraft?
Other bands it's capable of receiving:
FREQUENCY RANGE
Citizens/Business Band 25.0- 27.995 MHz
Amateur Band (10 Meters)
29.0- 29.7 MHz VHF Low Band 29.7- 50.0 MHz Amateur Band (6 Meters) 50.0- 54.0 MHz
Aircraft Band
108-137 MHz
Military Land Mobile
137-144 MHz
Amateur Band (2 Meters)
144-148 MHz
VHF High Band
148-174 MHz
Amateur Band (1.25 Meters)
216-225 MHz
Federal Government 400-420 MHz
Amateur Band (70 cm)
420-450 MHz
UHF Standard Band 450-470 MHz
UHF T Band
470-512 MHz 800 Band 806-956 MHz [Less cellular] Amateur Band (25 cm) 1240-1300 MHz
