Scannercast keeps messing up
magillapd
North Richland Hills, TX
My feed stops streaming even though scannercast still says it's running. When I click stop broadcasting it pops up with an error and these are the details it lists. Anyone know what could be causing this?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Error in the application.
-2005401480 (DSERR_NODRIVER)
at Microsoft.DirectX.DirectSound.CaptureBuffer.Stop()
at Istrib.Sound.SoundCapture.StopDirectSoundCapturing()
at Istrib.Sound.SoundCapture.Stop()
at Istrib.Sound.Mp3SoundCapture.PerformStop(CapturingProcess capturing)
at Istrib.Sound.Mp3SoundCapture.Stop()
at ScannerCast.ScannerCast.StopAudio()
at ScannerCast.ScannerCast.stopButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3625 (GDR.050727-3600)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ScannerCast
Assembly Version: 1.0.0.0
Win32 Version: 0.14.10307.0
CodeBase: file:///C:/ScannerCast/ScannerCast.exe
Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3624 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Istrib.Sound
Win32 Version: 1.0.0.0
CodeBase: file:///C:/ScannerCast/Istrib.Sound.DLL
Istrib.Sound.Mp3
CodeBase: file:///C:/ScannerCast/Istrib.Sound.Mp3.DLL
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/ScannerCast/Microsoft.DirectX.DirectSound.DLL
Microsoft.DirectX
CodeBase: file:///C:/ScannerCast/Microsoft.DirectX.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
t1e8eppu
yeti.mmedia
Assembly Version: 1.0.3688.18337
Win32 Version: 1.0.3688.18337
CodeBase: file:///C:/ScannerCast/yeti.mmedia.DLL
yeti.mp3
CodeBase: file:///C:/ScannerCast/yeti.mp3.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PeterGV
K1PGV, ScannerCast author
Mont Vernon, NH
"DSERR_NODRIVER" means that the (software) driver for your sound card is no longer available.
It LOOKS like your sound card is dropping off line... what type of system is this, and what kind of sound card are you using? This is a relatively common error with users who have USB sound cards that are not securely attached to the system (for one example).
Peter
K1PGV
