Just curious on the Config tab in the service block it has a Max Clients, what does that mean? Can that be set to something other than 0?
If you let your cursor linger over the
Max Clients control on the form, you'll see a tool tip pop up that says:
Max Clients
The maximum number of clients that
you'll allow to connect to ScannerCast at the same time.
Clients that connect after the maximum has been
reached will be quickly disconnected by ScannerCast.
A value of 0 means there is no limit on the number of
clients that can simultaneously connect.
So, this applies to direct connections to ScannerCast only.
Chances are that your disconnects are due to SOMETHING in your network or computer infrastructure... I'm not saying it couldn't be a bug in ScannerCast, but there are several hundred copies of ScannerCast running 24x7 for weeks at a time without disconnecting. I have two (hmmm, well, three right at this moment).
So, lacking any additional info, I'd say this has to be a network or computer issue.
Sorry I can't help more,
Peter
K1PGV
