I see its been almost 8 months since the SW author (or anyone else) has discussed this app so I wonder what the future holds for it..
I was unable to install. The log file is below. Note that I do NOT have any version of ScannerLive installed on this system and to the best of my recollection never have had.
On the optimistic side allow me to suggest that for this to be worth $20 to me (even assuming I could get it to install on my system), it would need a "Tivo" type playback. In other words it could buffer the last xx minutes of audio on each feed so that if you just caught the tail end of a transmission, or just didn't hear it clearly you could hit a button to rewind the last 10 seconds or so. This would be of great value to me.and would only need to buffer at least 10 minutes.
Now for the log for the failed installation:
PLATFORM VERSION INFO
Windows : 6.1.7601.65536 (Win32NT)
Common Language Runtime : 4.0.30319.269
System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100)
clr.dll : 4.0.30319.269 (RTMGDR.030319-2600)
dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll : 4.0.31106.0 (Main.031106-0000)
SOURCES
Deployment url :
http://skywatch.org/scannerlive-64/ScannerLive.application
Server : LiteSpeed
Deployment Provider url :
Application url :
http://skywatch.org/scannerlive-64/Application Files/ScannerLive_1_0_2_0/ScannerLive.exe.manifest
Server : LiteSpeed
IDENTITIES
Deployment Identity : ScannerLive.application, Version=1.0.2.0, Culture=neutral, PublicKeyToken=aec15283d7c8791e, processorArchitecture=msil
Application Identity : ScannerLive.exe, Version=1.0.2.0, Culture=neutral, PublicKeyToken=aec15283d7c8791e, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
* Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of
http://skywatch.org/scannerlive-64/ScannerLive.application resulted in exception. Following failure messages were detected:
+ Unable to install this application because an application with the same identity is already installed. To install this application, either modify the manifest version for this application or uninstall the preexisting application.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [9/14/2012 10:30:18 AM] : Activation of
http://skywatch.org/scannerlive-64/ScannerLive.application has started.
* [9/14/2012 10:30:18 AM] : Processing of deployment manifest has successfully completed.
* [9/14/2012 10:30:18 AM] : Installation of the application has started.
* [9/14/2012 10:30:19 AM] : Processing of application manifest has successfully completed.
* [9/14/2012 10:30:28 AM] : Found compatible runtime version 2.0.50727.
* [9/14/2012 10:30:29 AM] : Detecting dependent assembly Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil using Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil.
* [9/14/2012 10:30:29 AM] : Detecting dependent assembly System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
* [9/14/2012 10:30:29 AM] : Detecting dependent assembly WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=msil using WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=msil.
* [9/14/2012 10:30:29 AM] : Detecting dependent assembly System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
* [9/14/2012 10:30:29 AM] : Request of trust and detection of platform is complete.
* [9/14/2012 10:30:32 AM] : Downloading of subscription dependencies is complete.
* [9/14/2012 10:30:32 AM] : Commit of the downloaded application has started.
ERROR DETAILS
Following errors were detected during this operation.
* [9/14/2012 10:30:32 AM] System.Deployment.Application.DeploymentException (Subscription)
- Unable to install this application because an application with the same identity is already installed. To install this application, either modify the manifest version for this application or uninstall the preexisting application.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.SubscriptionStore.CheckApplicationPayload(CommitApplicationParams commitParams)
at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
