ScannerLive For Windows PCs Now Available!
rdale
Lansing, MI
A beta-test update (free for all) is posted on the forum.
1) Potential fix for bug when delay is set to 0
2) Removed "Mute: ALL" option (stop button does that already) and changed it to "Unmute: ALL" which allows you to hear all conversations at once when checked.
exkalibur
York, Ontario
Apologies if this has already been asked already. A friend of mine in the media biz uses this app and it seems pretty good. What will happen once the divorce of RadioReference is done, and Broadcastify is up and running? I take it, it'll be a transparent change?
KMA367
Redwood Coast, N Calif
Terrific
Appears to be working (with zero-second delays) like a champ... and as a sort of bonus I "had to" upgrade from .NET Framework 3.5 to 4.0, which I didn't even know existed, in order to install it.
I'll have to play with the Unmute All... perhaps very late in the night and my ears are lonesome. And since multiple instances of ScannerLive can be run simultaneously, I guess it's theoretically possible to listen to 100 different streams simultaneously. My wife will love this. :roll:
But seriously, MIke, ScannerLive a top-notch application. Thanks for bringing it to us.
joetnymedic
West Haven, CT
So far so good. I downloaded the program the other day and toyed with it. I said I was gonna buy iy and sure did. Now all I have to do is put it on my other computers and I'll be all set as sometimes I take my netbook with me instead of my laptop. Thanks
rdale
Lansing, MI
I've moved to the Visual Studio 2012 platform, and tweaked the code a bit in preparation for more updates.
Uninstall the existing ScannerLive and install this if you want to test. It's still a beta.
32-bit Windows
ScannerLive
or
64-bit Windows
ScannerLive
rdale
Lansing, MI
You don't know how good that makes me feel :) It was my last scare in moving to Win8, and I tested on two 32-bit and one 64-bit machines before this final release.
rdale
Lansing, MI
It allows you to "scan" up to 10 online feeds at the same time, while listening to one at a time. Just like a scanner you have now, but online. It's available as a free trial, so feel free to go to ScannerLive and download it there too.
N2JDS
St. Peters, Mo
Newest version works great on my WIN7-64bit laptop.
Another quality product by rdale!!!
Same here, I do have a question though, how much work would it be to have a separate volume slide for left and right speakers built into the app for stereo feeds?
RonnieUSA
Rowan County,KY (Morehead)
Sorry the 64 bit Won't install on Windows 8 64 bit, just tried it.
I think I would like it, because I could listen were my brother lives in Ohio.
Here is the error from the install log.
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.2.0 {version}
Running checks for package 'Windows Installer 3.1', phase BuildList
The following properties have been set for package 'Windows Installer 3.1':
Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true
Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
'Windows Installer 3.1' RunCheck result: No Install Needed
Running checks for package '.NET Framework 3.0 (x86)', phase BuildList
Reading value 'InstallSuccess' of registry key 'HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v3.0\Setup'
Read integer value 1
Setting value '1 {int}' for property 'NetFx3Installed'
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer'
Read string value '9.10.9200.16433'
Setting value '9.10.9200.16433 {string}' for property 'IEVersion'
The following properties have been set for package '.NET Framework 3.0 (x86)':
Property: [IEVersion] = 9.10.9200.16433 {string}
Property: [NetFx3Installed] = 1 {int}
Running checks for command 'DotNetFX30\dotnetfx3.exe'
Result of running operator 'ValueEqualTo' on property 'NetFx3Installed' and value '1': true
Result of checks for command 'DotNetFX30\dotnetfx3.exe' is 'Bypass'
Running checks for command 'DotNetFX30\EnableDotNet3.exe'
Result of checks for command 'DotNetFX30\EnableDotNet3.exe' is 'Bypass'
'.NET Framework 3.0 (x86)' RunCheck result: No Install Needed
Running checks for package '.NET Framework 3.5', phase BuildList
Reading value 'Install' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v3.5\1033'
Setting value '1 {int}' for property 'DotNet35InstallSuccess'
The following properties have been set for package '.NET Framework 3.5':
Property: [DotNet35InstallSuccess] = 1 {int}
Running checks for command 'DotNetFX35\dotNetFx35setup.exe'
Result of running operator 'ValueEqualTo' on property 'DotNet35InstallSuccess' and value '1': true
Result of checks for command 'DotNetFX35\dotNetFx35setup.exe' is 'Bypass'
'.NET Framework 3.5' RunCheck result: No Install Needed
Launching Application.
URLDownloadToCacheFile failed with HRESULT '-2146697210'
Error: An error occurred trying to download 'http://skywatch.org/scannerlive-64/ScannerLive.application'.
rdale
Lansing, MI
I realize that :) Just above that I posted a direct link to the test 64-bit version which should work with Win8. That's what I want you to click...
