"I don't know why the letter "F" is not allowed."
Because "F" is involved in MDC "All Calls", IE if you were to page "FFFF", all radios with MDC enabled, presuming that MDC RX Alerts ara enabled in CPS/RSS, they would all go off on that frequency. One of my AstroSaber's can do it, but that's the only radio I have that can from the front panel.
Close: in the MDC1200 realm, F in any digit is considered to be a wildcard. So, for instance, a command sent to "###Fh" would be addressed to 15 addresses: ###0h through ###Eh. Wildcard are generally used where MDC1200 ID schemes used tiered digits. For example:
First Digit: 1 is portable, 2 is mobile, 3 is control station.
Second Digit: 1 is command staff, 2 is suppression company, 3 is other
Third Digit: serial within second digit.
Group calls (of which "all call" is the ultimate example) are usually handled differently. For sub-groups, you can assign all members of a given sub-group with the same
three-digit "secondary" ID, and a command sent to that ID with an E prefixed to it will be interpreted as a group call. You could make an "all call" this way, but a simpler way involves using a "group tone" on the primary ID, such as A-B, Long B. Here, instead of sending the A-B tone sequence, you send 6 seconds of the B tone, and all units with the same B tone will respond.
