Sure. They really are much like a power strip, except for DC. If you have a place to mount them, they'd be very nice. There are several different ones to choose from, the number of ports it has determines the length. Metal case, each port has its own fuse, a few models have some over/undervoltage indicators and alarms.
One note on the fusing, if you get a model that has no wire pigtail hanging out the side, you just use one of the ports as the input. (They don't count that port in the product name, so a "5-port" RigRunner actually has six, one for the input.) That port also has a fuse, you just put a larger fuse in that slot that will cover the max amp draw you want to allow. They default to having the large fuse in the first slot, but all the powerpoles are attached to a common bus inside, and are identical so it doesn't matter which one you use for the power feed.
Also note, the "standard" size powerpoles are rated to 45A, above that the bodies and contacts start to get larger. Below that, there are three pin "sizes" - 15A, 30A, 45A - but the actual contact points are the same. The size difference is just the crimp barrel, for different wire diameters.
