Scanning 220mhz
RyanXTS
What scanners are available that are capable of scanning 220mhz Passport radio systems?
loumaag
Silent Key - Aug 2014
Katy, TX
No scanners can track a passport system. However most modern scanners will cover the band and hence you can always listen in conventional mode.
RyanXTS
Thanks.. does anyone know if there is a scanner in the works that will?
loumaag
Katy, TX
Probably not. There just isn't enough call for it to be feasible from a business standpoint. Now if you have an interest, I suggest you search through the topics in the LTR Systems forum. There have been programs written which will track LTR systems and you may find some help there.
Just curious, where are you finding a LTR Passport system in th 220 MHz range?
loumaag
Katy, TX
RyanXTS said:
In maryland... I happen to be installing them...
HA! :lol:
So, really this was an intelligence gathering foray. :wink:
RyanXTS
You could say that... :wink: I also happen to need a new scanner as my 2048 doesn't even support analog trunking... although we are supposed to go to digital eventually... :eek:
EricCottrell
Boston, Ma
Spleen
Westminster, MD
The Baltimore system comes in S8 downtown. If you put your radio in SSB mode, you can hear the data burst rather well...
