scanning all bands help
swm239
Hello, I am trying to scan the military band, I have created it and selected it and it works on that but it then also goes through everything else such as ham, marine, fm radio, air band etc. Can't seem to find how to turn these off. Any pointers would be great, thank you
swm239
Hi, I am on the scanner plug in on airspy 2
wtp
Port Charlotte FL
i'll come in again...
can you be descriptive about your setup
and again are you using a radio scanner ?
SDR is meant to run on a computer and that is it.
BM82557
Berkeley Co WV
If you are using SDRSharp and the Frequency Scanner plugin and you are talking about Military Aircraft this is how mine is setup and it works fine , you select the range you want then click on the Scan button --
swm239
Hello, yes my screen looks like yours, I was using scan all with save new, I changed mine and it says " scan only memorized except new," yours shows exclude new. I am on version 1.0.0.1822 and it does scan the 225 to 400 but then it is going through fm radio, ham, marine, air band etc. How do I get those other bands turned off? Thanks
BM82557
Berkeley Co WV
Some videos that have helped people out with the plugin --
