Scanning at a golf tournament
Will001
Lexington County, SC
Hi everyone,
I am going to a golf tournament in NC in a few days and I was wondering if it is legal to bring a scanner and/or a Motorola radio into the tournament? I'm assuming it's legal, but I want to play it safe so I don't get my radio confiscated.
radio3353
Is the golf course private property? If so, you have to follow their rules.
And even though the public may play on it, it may still be (and probably is) private property.
Instead of asking your question here, read the rules if they publish them or call the course.
majoco
Stirrer
New Zealand
If you were watching a particularly tense part of someone's game and your radio suddenly burst into life, I think you'd find yourself out on the road accompanied by a couple of burly security people rather quickly. :)
marksmith
Anne Arundel County, MD
It is private property, plus the club turns operations over to the PGA for the tournament. It is a major tournament, and security will be high. You will go thru a metal detector like you are getting on a plane and you might even be wanded.
The website or your ticket probably contains a few paragraphs of rules. It may not specifically mention scanners, but I would be willing to make a substantial wager you would not get on the grounds with one.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
ecps92
Taxachusetts
Attending ? - Leave it in the Car/home
Generally while on the grounds - Cellphones need to be Off or on Silent
and any radio/two-way will be prohibited unless part of the public safety or Association Operation.
On-Site Scanning ? - find a Fast Food or Mall near-by and search away
However don't be surprised if many have moved to DMR
Hi everyone,
KE4ZNR
Radio Geek
If this is the Wyndham Championship they have been granted an STA to operate a DMR system during the event.
Marshall KE4ZNR
Code:
IG WQZT756
Creative Communications Sales & Rentals
[This STA is to operate onsite radio system for Wyndham Championship.  This is a Golf Tournament. We will utilize approximately 255 radios for security, communications, and first aid response]
Control Point 1 - Wyndham Championship @ 3201 Forsyth Drive, Greensboro NC 602-721-1857
(link)
08/01/2017 License Issued
Special Temporary Authority expires 08/20/2017
1 - Greensboro (GUILFORD) NC  5.0 km radius around center point (map)
 451.7375   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 456.7375   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 451.8875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 456.8875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.1375   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.1375   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.1875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.1875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.6875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.6875   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.7125   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.7125   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.1125   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.1125   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 452.2625   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
 457.2625   MO     Ant: 1   20p    2e     Units: 255                   7K60FXE (DMR)
marksmith
No problem. But I anticipate you learned it's not worth it.
Unless you want to try scanning from the parking area. However, for most tournaments, parking is well away from the site, with bussing to entry gates so they can control the flow in and out even from off premises, where the metal detectors and such are, preceeding the lines to get on a shuttle to the course.
Since they are generally using low power FM for communications, and no repeater, you might not even pick up much from parking.
There isn't much to hear other than security and maybe some concessions organization.
They don't use radios any more to report what is happening on course. That is done with smartphones and laptops with a recorder going with each group.
What I would recommend if they have it, are the small earpiece receivers they often supply by some sponsor. This gives a broadcast of the tournament that you can listen to in one ear while roaming the course. When onsite, these allow you a better connection with what is going on everywhere, and where various players are.
ofd8001
Louisville, KY
I'd also suggest locating the frequencies used by whatever television network is covering the event. When the Kentucky Derby comes to town, it's pretty interesting listening to them (at least for a while). But they tend to be low power simplex operation too.
The local public safety system may use different talkgroups for large events such as these (assuming it is a TRS). So some attention might be given to Event, Special Event, Mutual Aid, Interoperability labeled talkgroups.
ecps92
Taxachusetts
450-451 and 455-456 are the normal regions to look for the Media Crews.
However, they generally also get an FCC STA [Temp License] and [my experience] in the past this has been in the Regions un-used T-Band, so don't skip the 470-512 Region
I thought about scanning the tv crew and now I'm definitely going to try [emoji6]
