scanning detroit simulacast on reverse?
313RADIO
i was thinking about programming my scanner with the input frequency's for the trunked system and scan them conventionally, that way i will here whats going on close by. will this work? will they decode?
313RADIO
i am thinking about in and around the same building?
how do i know what the reverse freqs are ? whats the normal offset?
rdale
Lansing, MI
Probably
Check the database page - click on the tower ID and it'll bring up the frequencies.
313RADIO
heres what i figured out
Detroit has 10 individual towers
each tower broadcast same 26 channels and 4 control channels all the time
the repeater offsets are -45 Mhz from the output frequency
im gonna try programming in and see if it will work....
MOTST
Lansing
That is good information. 30 channels total, and the input is -45 Mhz the TX frequency.
313RADIO
it seems to work ok i have picked up transmissions in and around the local vicinity up to a few blocks away. audio is perfect no problems on audio going digital yet.
however 2 problems
2. you will not hear dispatch
1. you don't know what your listing to
i setup a 3 rd open bank and I switch to that real quick to see if i can ID the TG... seems to work ok so far.
MOTST
Lansing
You won't hear dispatch as they are connected through the CEB to the network. No actual RF at the dispatch level. Going to conventional mode, you loose all the trunking "goodies" such as ID and TG. Another drawback is that different PTT may show up on another freq. if the station timed out.
