Baofeng Scanning Local Frequencies in Emergency Situations
GracelandPro
I have a Baofeng UV-5RVS+ and would like to use it as a scanner only. With a bad Hurricane on the way it would be useful to get information from my local emergency Operations Management. I found the frequencies (listed below) that I would like to listen to and have programmed them into the radio but when I pull them up I don't hear anything. The only frequency I can hear is 162.400 which is a weather channel that keeps repeating itself. It's not live in real time. Any help would be greatly appreciated. Also, I do not have a license and I am not wanting to transmit anything. Just want to hear what's going on around me while the power is out for the next week or so.. Thanks again.
FrequencyLicenseTypeToneDescriptionModeTag
153.69500KNCH619 RMS. Ms. Electric Power AssocP25Utilities
154.41500WPYY799 RM186.2 PLFire DispatchFMNFire Dispatch
154.22000KXQ906 BMFiregroundFMNFire-Tac
155.83500WPYY799 RM186.2 PLFire AdministrationFMFire-Talk
45.92000KUV725 BMEmergency ManagementFMEmergency Ops
46.04000KUV725 BEmergency ManagementFMEmergency Ops
155.88000WZC694 RM118.8 PLPublic WorksFMNPublic Works
Bay Saint Louis
Frequency
154.29500WQDR814 RM203.5 PLFire DispatchFMNFire Dispatch
150.80500WQDR814 M203.5 PLFiregroundFMNFire-Tac
154.10000WQCK693 RM136.5 PLPolice Car-to-CarFMLaw Talk
Waveland
Frequency
158.79000WPKG499 RM364 DPLPolice Car-to-CarFMNLaw Talk
alcahuete
Southern California
There's nothing special about programming those frequencies. Since you're hearing the weather (which is always the recording), I'm assuming you are programming the other frequencies correctly. Are you close enough to those locations to hear them?
You are not going to hear the S. Ms. Electric Power Assoc. They are using P25, and the Baofeng is not a P25 radio. You should be able to hear the others though.
