LTR Scanning using the BC796D
The 796D will do an excellent job of LTR scanning IF you enter the frequencies correctly in their LOGICAL channel programing sequence. This sequence was determined by the installer and often is difficult to ascertain because on low volume traffic systems comms tend to default to a "home" channel and other system channels may have low volume traffic. Additionally one or more LTR frequencies in a logical system may not be active for whatever reason.
I wrote a short article on helping id LTR frequencies recently for Monitoring Times magazine. Any iding process is time consuming. There can be up to 20 channels in an LTR system. First I identify all of the LTR frequencies licensed to the particular LTR system. Then I program the lowest frequency into ALL 20 channels on the selected 796D bank for that system. When a transmission is made, I quickly press/release the "hold" button and visually id the stopped channel on which the audio was heard. I repeat this several times to confirm audio is being received on this frequency. If the audio is on channel 9 then I write down that frequency and channel 9 as the relationship. I then delete the lowest frequency entered and enter the next highest frequency for all 20 channels and repeat the process. Assuming all 5 frequencies are active in a 5 channel system and I id all of them with their channel relationships, I erase the last frequency entered for the 20 channel check and enter the 5 frequencies and their associated channels. That's it. I assume you are using ARC250 software otherwise plan to spend a lot of time manually entering information.
The Radio Shack Pro96 supposedly will automatically configure LTR frequency/channel relationships. The downside is that it is more prone to miss LTR transmissions from what I have read.
As mentioned, the biggest problem in iding LTR channels is little or no activity on one or more LTR systems. Much time is spent awaiting for the comm traffic volume to increase to where other frequencies in the system will activate, if ever. The described process does work for the most part, but it is not perfect and I am not aware of any alternative id process that is faster or more accurate using the 796D.
The best source is to have the installer/maintainer provide you with the frequency/channel relationships. I doubt if many installers would do this if queried.
