Scanning OPP with AR8200 Mk3
Cambridge, Ontario
Having an issue picking up waterloo county OPP can anyone help with the frequency using scanner AR8200 mk3.
I have tried scanning through 141.0000 to 145.0000 and using my phone app as a guide for when it is broadcasting with no luck.
Thank you for any help.
Cambridge, Ontario
Hi Guys,
Not sure if someone can help. Trying to get OPP on my scanner AR8200 Mk3 can not find frequency am I missing something?
I do not understand the talk about bell net. Is this what I need or is it not finding the frequency.
Regards
Des
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Try these:
Code:
Frequency 	Input     	License 	Type 	Tone 	Alpha Tag 	Description 	Mode 	Tag
410.86250 	416.31250  	 	RM	123.0 PL	OPP VR01	VR01 - Vehicular Repeater 	FMN 	Law Dispatch
411.31250 	416.51250  	 	RM	107.2 PL	OPP VR02	VR02 - Vehicular Repeater 	FMN 	Law Dispatch
411.51250 	415.86250  	 	RM	136.5 PL	OPP VR03	VR03 - Vehicular Repeater 	FMN 	Law Dispatch
Also, 412.4625 and 413.5375
Forts
Ontario, Canada
Hi Guys,
Regards
Des
Fleetnet is a trunked radio system, which requires a digital trunking scanner to properly follow OPP. The AR8200 is neither a digital or trunking capable radio so Fleetnet won't be an option. What you can do is enter the vehicular repeater frequencies that mciupa listed. If there are any cruisers somewhat near your immediate area you'll be able to pick up some activity.
