policefreak
Is anyone in the southern New Jersey area have this radio? If so how does the sensitivity stack up against say...the HP-1, or the PSR 500/Pro 106? How is programming it using the database for you listeners in Burlington County or monitoring the NJSP where there are lots of new talkgroups always coming up? (Though they did clean up the database fantastically for Burlington!) How is the sensitivity of the PSR 800 for you fringe listeners out there in Gloucester, Burlington, Southern Camden, etc trying to pull in Philly and Montco and Bucks and other distant digital signals with the RS 800 antenna? Can it receive distant control channels ok? Alright, how sensitive is it even on analog stuff? And overall how easy do you think it is to use to monitor our area? How about traveling with it and monitoring different stuff along the way (like taking a trip up to the poconos.)?
The reason I ask this is because well, first of all I'm not all that familiar with the GRE models, though I'm definitely doing my homework. I'm looking at the PSR 800 for the fact that Camden County's new P-25 X2 system is going up. They have a similar system in Maryland and the 800 seems to be picking the system up. I also happen to be in the unique situation where I am right on the very fringe of receiving a lot of systems. If you draw a line at my house anything NW of it and you'll be able to receive those Philly, Montco, and Bucks systems. Anything SE of that line...nada, just Camco. (And we are just 1.5 miles from the Burlington county line) My 396xt does ok, but has lots of trouble picking up Philly. Some say the 800 does better than older models on distant channels, others, not so. For our area want to see what you think. I will invest in a better 800 antenna eventually when I have access to an attic or a roof. Open to any input you have.
