Scanning Space And Satellites With Close Call ?
darkwolf
Oklahoma
Has anyone had any luck using the close call feature in the bcd396xt scanner I have tried but with no luck at all what other methods using the features in the bcd396xt scanner would you recommend using
Rt169Radio
CT
I think close call really only works horizontally,am not sure that it works going straight up.But again am not sure.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Close call means just that - close. A satellite has far too weak a signal to even begin to capture using this.
Do some homework on how to hear satellites - it can be done with a scanner and the right antenna, but you need a few tools, particularly knowing what satellite you want to hear, and how to track it. There are such resources - and undoubtedly there are more that you can find with a well-ordered search on the net - here...
SATCOM - The RadioReference Wiki
HTH...Mike
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
In order for close call to trigger, the signal strength needs to be much much higher (?20db I think?)than anything else the scanner is hearing. Close call does not care if the signal is above or horizontal to the plane the scanner is on. Sattelite signals are not going to be anywhere near strong enough to trigger close call.
dave3825
Suffolk County NY
The close call works in all directions. Up, down, left, right. like stated, the signal needs to be close.
kayn1n32008
ØÆSØ
Sector 001
Distance to the source is not overly relevant, although to be 20db above noise, a signal certainly needs to be strong to trigger close call. I have seen situations where close call triggers 2-3+km from the signal source. So close is a relative term.
KB7MIB
Peoria, AZ.
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
I've gotten NOAA weather radio on my GRE PSR-500's Sweeper (the same as Uniden's Close Call) and the transmitter is about 22 miles away.
AK4GA
Monroe, Georgia
But its also transmitting with 20 Kw.
KB7MIB
Peoria, AZ.
Exactly. So "Close" is relative. It's all about the signal strength that the scanner is seeing, as was stated before me :)
gewecke
Illinois
....You're gonna have to get a little closer to the sat. :D
73,
n9zas
darkwolf
Oklahoma
I do appreciate everyone into put on this post and all input is very helpful to me I just wanted to thank you everyone very much ………………DarkWolf
bryan_herbert
Las Vegas, NV. DM26jc
I've received Close Call hits from aircraft using just a whip. You might (and I use that term loosely) catch a satellite if you use a high gain directional antenna, a low noise - mast mounted preamp and quality coax like LMR-400 or better.
But at the same time this could also overload your receiver.
