I've got two local businesses that use 153.0125 and 153.00500. One uses DCS and the other uses CTCSS.
If I'm in the middle of them geographically, my TRX-1 will pick both up separately and use the right codes, but will also get confused and combine them or jump between them if both are transmitting at the same time. Is there a way to distinctly separate these in the scanner, or is this kind of interference/mixing normal?
Thanks!
Thanks!
