Scanning with XG-75
Aidan603
I’m looking into buying an XG-75. I guess I’m wondering if it would be capable of scanning my local PD frequency? It’s a P25 frequency. I already have an analog uniden scanner that I use to scan my local FD, so I know the basic about scanning. The one I’m interested in buying doesn’t have many buttons on it, so I’m curious about how it would be to program it to tune into my local PD or if that’s even possible. It’s relatively cheap, and I don’t feel like spending big money on an actual digital scanner. Thank you.
K2NEC
What does your local PD use? What frequency, conventional or trunking, is it encrypted, etc etc.
You would need a programming cable which are hard to come by and the RPM which is a couple hundred dollars. Depending how simple, someone on here might offer to program it for you.
To be honest it's easier to get a scanner, but since you seem willing to learn, I'll bite.
Aidan603
The frequency is 154.7175. It’s a conventional frequency and I doubt it’s encrypted since I live in a small town in the middle of nowhere.
Aidan603
Luxury Subscriber
LATA 722
This can be a very deep hole you can fall into easily. Tread carefully and do all your homework before spending money.
The XG-75 is single band. It'll only do one band. You will be limited to listening to traffic on that single band and no others.
They come stock with analog and P25 conventional only. All other features (P25 trunking, EDACS, OpenSky, etc) are all additional cost items. The radio doesn't necessarily include those features and you would need to make sure it had what you wanted. Adding it later is possible, but expensive (way more than a new digital scanner)
Programming software (RPM) is expensive.
Programming cable will be required.
Programming these sorts of radios is not as easy as a scanner. It's complex and has a lot of functions that need to be set up correctly.
On the other hand, the receivers are usually much better than a consumer scanner.
But you really need to consider all the costs and all the risks involved. If the radio doesn't have all the features you want, you'll end up adding them. P25 Trunking is a $950 (list price) option.
And any used radio you buy, consider that the battery is likely worn out and will need to be replaced. Antennas are usually beat to hell, too.
It's pretty rare that you can buy a used radio like this and come out ahead of just getting a new scanner.
jaspence
Michigan
A Uniden BC125AT will easily handle that frequency for a little more that $100. Also great for air and other conventional listening. It's fun to have expensive "toys", but save your money.
jaspence
Michigan
Ignore above. Forgot the P25 in my reply. A reasonable choice would be a Whistler WS1040, which can do P25 Phase I.
