Scanning
snapperq
Tiffin, ohio
I have a Uniden BCD996XT scanner. When the scanner stops on a stored frequency it displays
the frequency but while it broadcasts, a (second frequency also flashes) making it difficult to know
which freq. is transmitting.
Can someone tell me if I have an incorrect setting or is this normal?
Thanks in advance!
jackj
NW Ohio
Could you have a different frequency set as a Priority and the scanner is checking that frequency? If that's not it, check WX and see if you have it set for weather alerts.
buddrousa
NW Tenn
What I think you are seeing is the control channel freq1 and voice channel freq2 and if your scanner does ID's you chould see fleet id then radio id.
UPMan
In Memoriam
Arlington, TX
I suspect Tone Search is turned on for the channel. The flashing frequency would be the subtone in used on the frequency (CTCSS or DCS).
