W6KRU
I can't modify scansets in EZScan. The default in the software is everything assigned to Scanset 1 and I can't change that or rename scansets. What am I missing?
I have the same issue here. I can modify them from the scanner but not on my PC
Where are you not able to change the scanlists? During import or elsewhere? Just tried it here and had no issues once I've selected the channel(s) to change and then click on the scanlist column.
Mike
I have a PSR800 and assume the software is still the same.
The only selection I have:
Open software
Click on advanced tab at the bottom
With the advanced page open, look at the top right of the page
is labeled "scan sets"
click on scan set mode and make selection and see if that fixes the problem.
There appears to be a glitch in 2.0 of the software that is preventing us from being able to do anything with ScanSets. For whatever reason I cant rename, select ScanLists, or even enable or disable them. You can see everything but clicking does nothing.
Is the "2.0" (assuming EZ Scan?) Software only available to those with a WS-1080? I have the GRE 800 and a quick check shows I am up to date with Vs-1.8 ? Just curious.
Thanks,
rwier
Looks like Whistler released an update to correct the issue with scansets.
Mike
