Scantenna-CB
dentman69
Odessa Missouri
Does anyone know if you can have a CB connected to a outside scantenna while other scanners are connected via a splitter. Or may it FRY the the scanners when you transmitt on the CB ? Thanks!
kb2vxa
Banned
Point Pleasant Beach, N.J.
Hi Dent and all,
You'll fry your final if you try to transmit using a Scanenna for CB, the SWR is such you can't count that high. Just use the proper antenna(s) for the job and have them adequately spaced so you don't blast your scanner's RF section with more volts than it can handle.
Bill, which side is the sticky side? I asked Yoda but somewhere in all that double talk he said to ask you.
