SCHP Cherokee County
joncleve
Western NC
What talkgroup does the SCHP in Cherokee County currently use? I use to have them in Palmetto 800 CH 49 21520 but I'm not getting anything on that.
Thanks,
Jon
brian
DB Administrator
South Carolina
Most frequently, they use Ch. 52 Chester/Fairfield 21392. However, Troop 4 dispatchers regularly use patches on the SCHP dispatch talkgroups when a single dispacthers has to cover multiple channels simultaneously. If you don't have a scanner that properly handles patches, you may miss radio traffic depending on how the patch is set up. I would recommend programming all three Troop 4 dispatch talkgroups into your scan list/group and scan all three until you confirm which are most commonly used.
The other two Troop 4 talkgroups are York 46128 and Lancaster/Chesterfield 21104.
21520 is now a Troop 1 talkgroup, though it used to be used in Troop 4 several years ago.
