Scottsdale PD Question
chrisareston
Sorry Im really not new to scanning just new to phoenix and to Trunking. I have Scottsdale in my Pro 97 I used win 97 with a subscription from RR.com to upload the freqs directly to mu Pro 97. Well when I scan the bank It never stops on Scottsdale, but if I manualy go through the channles I hear Scottsdale PD but it does not follow ch to ch. Did it program something wrong? I should be able to scan right?
chrisareston
I reprogrammed the scanner again using Pro 97 and RR.com as a web import for scottsdale pd. It still does not stop on the freqs when it scans, but if I stop it on one of the channles it picks them up fine but does not follow the chan. It does stop on some of the chanles but I just hear like a digital noise? What could I be doing wrong?
918Dave
Glendale, Arizona
What frequencies did you use when programming Scottsdale? RadioReference also lists the OLD Scottsdale system. The Scottsdale system uses the same Control Channel frquencies listed under the Maricopa County system. If you live on the East side of the valley, the Thompson Peak site Control Channel primary and alternate frequencies should be used. If on the West side of the valley, the White Tank site frequencies are the ones to use. Also, did you set the bank and frequencies to Motorola mode when entering?
Dave
Glendale, AZ
chrisareston
Dave I used the ones listed under scottsdale I used the win97 programm to do a web import so I did not have to put all the freqs in myself it also put the talk groups. Just when it scans it does not stop but like I said I can manually stop on the channle.
System Frequencies
Site Description Freqs
001 Primary 851.33750 852.71250 853.36250 853.56250 853.76250 854.33750 854.58750 857.76250 857.86250
858.76250 859.76250 860.76250 860.96250 866.15000 866.20000 866.25000 867.15000 867.21250
867.28750 867.77500 867.81250 868.65000 868.80000 868.85000
DEC HEX Description
48 003 Scottsdale PD 1-Adam (South Dispatch)
80 005 Scottsdale PD 1-Bravo (HOT/Emergency)
112 007 Scottsdale PD 1-Charlie (North Dispatch)
144 009 Scottsdale PD 1-David (Info)
176 00b Scottsdale PD 1-Frank (TAC-1)
208 00d Scottsdale PD 1-George (TAC-2)
336 015 Scottsdale PD unid
464 01d Scottsdale PD 1-Edward (Events 1)
496 01f Scottsdale PD unid (Event 2)
784 031 Scottsdale City Water
1008 03f Scottsdale PD unid
3248 0cb Scottsdale Airport Ops
918Dave
Glendale, Arizona
The frequencies you've listed are from the OLD and no longer in use Scottsdale system. You'll need a scanner that is capable of monitoring digital systems such as the Pro 96, Pro 2096, or the Uniden models 296D, 396D, 996D etc. I cannot remember if the 97 is capable or not? With a digital capable scanner, you'd need to program in the Maricopa County system frequencies, . . . then enter in the Scottsdale talkgroup I.D.'s.
Dave
chrisareston
Ok I got the scottsdale stuff in now and am picking up Scottsdale! The only issue is that once and a while it will stick on a freq that sounds like a bunch of digital noise and its loud, if I lock that freq out it stops stopping on channles that have activity. Another thing Scottsdale is not digital right because I do not have a digital scanner and I am getting them and I have heard that they are not digital.
Thanks!
chrisareston
Thanks! I resolved the issue. I had to make sure closed was checked. It was picking up the digital talk groups that I did not have assigned in the scanner. When I click closed it only accepted the talk groups I had assigned which are only Scottsdale so im happy now, and am not getting that digital noise.
