Scrambled audio and talker alias
cellular
Just share my experience here. If you find your voice scrambled or distorted via echotest, if there is no antenna issue, then turning off "Send Talker Alias" at Conventional - Digital Common - Basic - Miscellaneous.
It solved my problem easily!
ottosykora
Basel, Switzerland
it depends on what repeater you are connected to. If your gateway is Hytera repeater, then alisa does not disturb. When using this function over motorola repeater or some other, then this function creates breaks in the data flow.
