Haven't had it in the shower, Haven't even carried it anywhere in about a week..I just now got to noticing, The bottom portion of the display glass was loose, Enough there was a crack that anything could have gotten behind.. Is the display supposed to off like this or should I fix it....Somehow?
Thus, Leads me to think, Could it be glue off the glass where it's come loose?
Ok, Another update, I've went back to where the glass was loose on the bottom right corner, Taken a cotton swave so that it's soft and wiped the inside of the glass where the spots were and they wiped right off, However, I have just pressed the glass back down on the bottom right corner (since this is all that was loose) and went all the way around to make sure it was down all the way, It appears it's staying down and not going to come up again, However, Although I do not understand why it came up the first time, if it does again, What's the best way to fix it here guys? Glue? Sticky Tac?
