SD card GRE 800
njscanmaster
Ridgefield NJ
What do I have to do with my new SD card Can some body wire down a list of thing I have to do with my new SD card Tomake the scanner work
Thanks. Jerry
AC2OY
Belleville,New Jersey
Hi Jerry!
Is the card currputed? If that is the case you might be able to reformat it using EZ scan's software. Good luck!!
jkahn
Very good looking Member
Silver Spring MD
Thanks. Jerry
Use EZ Scan option to format the card. If you already have programming in EZ Scan, it can be told to download the library and programming to the SD card after the format.
Be sure to update the library first!
JK ;)
