TRX-2: SD Card Question
gn32772
Hartford County, CT
Hi. I have a 1088 and just ordered a TRX-2. When the TRX-2 arrives, would it work if i put the SD card from the 1088 into it, in order to get it up and running quickly? Thanks.
troymail
Silent Key
Not quite - I believe the global settings will be different. It might work but with some weirdness.
Create a backup/archive of your programmed folders with the 1088 EZ Scan and then import them back onto your TRX-2 card when you get it. Or, buy a new SD card now (you should have a spare on hand anyway) and do the archive/restore thing now... Then, when your TRX arrives, you can just swap the card(s).
dwgelle
Meeker Co.- MN
@troymail's suggestion works. I did the same for a friend. Imported the Archive from my WS1098 in to the TRX-2 program.
