SD Card Read Error 'Discovery Review' (with bug details)
TigerMoth
BCD536HP, V1.06.10
I kept running into the above, 'SD Card Read Error', when trying to review my discovery results. The unit light would also turn off and the only way to proceed was to turn the unit off and then back on again.
I have a number of Micro SD cards, so confirming that this wasn't an actual card error was pretty simple.
On to finding the actual cause and repeating the problem...
I ran a discovery session between 440MHz and 460MHz. I then went to review any recordings whose length were not '0' and were not a multiple of '10' seconds (my default timeout).
I found that 441.950000 cause the Uniden to lock up. I inserted the card into my Mac and looked into the discovery directory for this run (/Volumes/BCD536HP/BCDx36HP/discovery/Conventional/A_RUN0004) and found the directory for this frequency (441950000_NFM_None) did not exist. I created the directory and put the SD card back into the Uniden to see how it would handle the directory existing but no files.
On browsing to the same run and frequency and selecting 'Play', the unit just beeped but didn't crash. Great! I have confirmed this is a software error.
I decided to write a little script to check the summary.log with the actual directory contents.
Code:
#!/usr/bin/perl -w
use strict;
open INP, "summary.log";
while (<INP>)
  #RunInfo_C	0.000000	-0.000000	0.0	440000000	460000000	AUTO	Auto	1	All	Off	30	0	Off	B
  #Summary_C_Log	440075000	None	NFM	27	3		C	0	0
  if ($_ =~ /^Summary_C_Log/ )
    my ($lt,$freq,$st,$mod,$dump) = split(' ', $_);
    if ( $st ne "None" )
      $st = (split('=',$st))[1];
    my $dir =  "${freq}_${mod}_${st}";
    if ( ! -d ${dir} )
      print "${dir} Not Found: $_";
Running this gave me the following output:
Code:
Filename (and message): Log type     Frequency     Tone      Mod   Seconds   Recordings
Code:
>> matt: check_bcdx36hp
440700000_NFM_None Not Found: Summary_C_Log	440700000	None	NFM	0	1		C	0	0
441950000_NFM_None Not Found: Summary_C_Log	441950000	None	NFM	12	3		C	0	0
455475000_NFM_None Not Found: Summary_C_Log	455475000	None	NFM	0	2		C	0	0
456562500_NFM_None Not Found: Summary_C_Log	456562500	None	NFM	0	1		C	0	0
440037500_NFM_None Not Found: Summary_C_Log	440037500	None	NFM	0	1		C	0	0
442900000_NFM_None Not Found: Summary_C_Log	442900000	None	NFM	0	1		C	0	0
455850000_NFM_None Not Found: Summary_C_Log	455850000	None	NFM	0	1		C	0	0
Hmmm, 440.70000 didn't crash the unit so what gives? It turns out, that if the recorded length for a frequency is '0' when trying to review a recording, it doesn't check the directory so doesn't instigate the system crash. Yay, we are making progress.
We can surmise from this, that if the software detects the recording length is less than 1 it doesn't create the directory and therefore doesn't save a file. So why haven't we got a directory for 441.950000?
Here I am making a few educated guesses based on the detail.log and experience.
It is my guess that the first time 441.950000 was seen it was captured with a '0' length recording and so a directory wasn't created. The next time 441.950000 was seen, and with a length longer than '0' seconds, the software checked to see if it has seen this frequency before, which it had, assumed the directory already exists and skipped creating the directory and went straight on to trying to write the file, which it failed to do silently.
I would be able to confirm this, but there is a bug with the detail.log - It doesn't log any captures that are '0' seconds in length, even though '0' second hits are recorded in the summary.log.
MStep
New York City
TigerMoth
It would seem from the underwhelming response, that you have even stumped the experts on here. Several weeks ago, i asked a relatively simple question here, but unfortunately I haven't gotten any nibbles yet either.
http://forums.radioreference.com/uniden-bug-reports/316740-stop-all-avoiding-bug-bcd536hp.html
I see you have a small number of posts here---- I'm wondering how long you've had your 536?
About a week :)
I have had a BCT15X and a UBC3500XLT for a while longer but only used them for manual scanning. I really wanted to use some of the more advanced features of the 536.
I came across another bug that someone else found on the forum, too. The one where you set it to 'Discovery' mode and it breaks out of 'Discovery' mode and starts a search/scan. By resetting the unit preferences, that cleared that problem. Next time I come across it, I will try and get to the bottom of it.
I will have a look at your bug, for you and see if I can replicate it for Uniden. I like problem solving, so it will be a bit of fun for me. I am without an antenna for a week due to some maintenance, so now might be a good time. Do you have an idea of how many avoids you had? Were there any particular ranges you can think of?
CalmWind
DFW area
Mine is doing the same thing with the dark display and "SD CARD Read Error" message.
Since this has happened several times, I realized it always happens on the particular file when I try to play it and even when I avoid 0 length ones it still happens. It seems something is corrupting the file or it is not being stored correctly. I can play other files fine.
My frequencies are in the 800+ MHz range..
