What is the largest sd card you can use in the HP-1? Thanks, John
jlally Member Joined Sep 22, 2010 Messages 15 Location Spokane, WA May 3, 2014 #1 What is the largest sd card you can use in the HP-1? Thanks, John
B bravo14 Member Premium Subscriber Joined Feb 18, 2005 Messages 4,589 Location Polk County FL May 3, 2014 #2 jlally said: What is the largest sd card you can use in the HP-1? Thanks, John Click to expand... Possible up to 32 GB Easier to Read HomePatrol Scanner Manual right hand side you'll see Reformatting the MicroSD Card if you click that will give info.
