Why don't you answer our questions in your other thread about which two counties you want to receive so that we can help with the programming?I order new sd card with county already program how to install new card whistler trx2
I recommend the 32GB MAX Endurance ones. YMMV.
How long do you keep the recorded files on the SD card? I move them after a couple of days to my PC and use the Universal Scanner Audio Player to more easily analyze the last days findings.True, it takes a long time to boot it up with 32GB.
"also unless you are recording large systems" - I do I love the Search & Record feature.
This is a thread about SD cards in the Whistler TRX-2. Your issues with SD cards in a Uniden SDS200 may or may not be pertinent to this thread. If you have tech support issues regarding your Uniden scanner, the Uniden Tech Support forum would be more appropriate.My SDS 200 Micro disk is corrupted...
It's the same issue with Uniden scanners. Choose "Clear User Data" in Sentinel and tick the box to view all drives. It could help if you first in Windows file explorer rename the SD card to "SDS200" so that it will be easy to spot in the drive directory.Thank you , will do and appreciate the responses .
Also, it does not support cards larger than 32 GB, and wasn't designed to work on the faster MAX Endurance transfer speeds.
A scanner are probably one of the least demanding devices you can use with a SD card compared to a camera, mobile phone, dashcam or wherever it is used. The slow bitrate and low amount of data only needs the slowest type of memory with lowest amount of write cycles you can buy. What could matter more are temperature specifications, especially if a scanner are used mobile.I like reliable SD-Cards but yes...I don't care about the transfer speed.
