SD statewide trunking system test (help needed)
radio5
Hi,
I'm here as a 'last resort' as our contacts in SD are presently unavaliable.
We're trying to test our radios (EFJ 5300) that are programmed with base code plugs provided by SD. We have an IFR 2975 (with SN/SZ). I believe we have the IFR info properly set up, but I do not get anything other than an "Out of range" message from the EFJ. I spent some time with Aeroflex on this issue to no avail (so far),
does anyone have any hints or things I can try to get these two devices to talk? We're trying to verifiy proper operation before deploying.
thanks
loumaag
Silent Key - Aug 2014
Katy, TX
I cannot help you directly, but I am pretty sure you would not have gotten any "real" help in the South Dakota Forum, so I moved the thread to here in hopes that some of tech guys could give you a hand.
radio5
we got things sorted out (kinda)
EFJ and Aeroflex are working on this 'common' problem.
thanks
