captkel
If you haven't heard, I GOT ONE yesterday and put it up today. Also if you haven't heard, I have been experimenting with a modified Military Air collinear antenna (formerly a 2 meter collinear). Now I have something to compare the collinear's performance to. Both antennas where mounted 30' up, feeding through a Par 225-400 Mhz band pass filter, This next part is only temporary...feeding to a Radio Shack VHF/UHF 10db variable gain mast mounted pre amp that is set at maximum, and RG6 coax.
With the SDL Log antenna I'm still receiving the same ground transmissions as before however 2 of the frequencies are 1 bar in signal strength stronger The local time here is 2:30 PM. Usually I notice that the signal strengths increase between 5 and 8 PM local and before sunrise so I'll recheck then. I assume I assembled the SDL correctly...For me it was a no brainier. , I'm waiting for a quality pre amp designed for this band to arrive, I did receive 50' of LMR400 and the proper jumper cables to go between the filter and pre amp. By the way I did run, as a test, the LMR400 direct from the SDL antenna to my Radio and I could only hear one ground transmission, barely. I'm about 35 miles away from that transmitter. More reports to come
KEL
KEL
