My opinion and I stand by it. Pretty piss-poor excuses and one sided. The software specifications are available to create drivers.
How did the developer of the USRP modded driver that enabled the R8600 and probably more "unsupported" radios to work with SDR#?
And why were they on an immediate mission to disable it in the next software version?
And also. Why did they make the previous version that did work not available?
But. There are fortunately archives not-airspy where you can get older versions.
Completely, 1000% stupid. Many volunteers develop plugins to add. There are pre-packed versions out there with every conceivable plugin you may or may not ever use. Some work well. Others, not so much.
Further. There are many applications that interface with many radios though the CAT, CI-V interface. And libraries such as Hamlib utilities and rigctl are easily used to control many, many radios with the interface. Satellite tracking, doppler correction.
Frequency management, scheduled recording.
Does the group that develops the software interfaces actually have those radios in their hand?
How about someone like Simon Brown? If I may drop a name. SDR-Console works. And you can use the server to control your radio remotely.
From cheap junk to high end. It's there.
We're talking freeware. I mistakenly purchased a lifetime subscription to DSD+ Fastlane. Thinking at the time it would miraculously work with my radio for trunk tracking. Well. Big bummer there. And not a finger on a keyboard to do anything about it.
It wasn't much. A few bucks. At least the SDRPlay RSP2 I have does work.
And who needs 47 antennas and holes bored in your home for all of the cabling? Well. Unless you're a freak I guess.
You don't "Need" the actual device in your hands if you can do a remote session and operate it.
With specifications for what is needed to make it do what you want it to.
Industrial automation. PLC's, motor controllers. Heck. If the NSA can screw up centrifuges in Iran half way across the globe.......
So the defense that an actual, physical radio in-hand is weak. Very weak. Their stand needs a big can of Flex Seal because it's not holding any water at all.
What does hold water is why not save an ounce of sweat and a bottle of Advil and enable the already built.
And YOU mentioned it. Ettus. I mentioned USRP. Modified driver to allow usage of different radios?
It's still out there. Airspy hated it. And whined about it. Then killed it's usage. But good 'ole v1732 is plugging away when I can stomach using it.
Ax me that, bro.
Again. In the case of SDR++. Once upon a time. It worked with my radio. Then. *Poof*. For some reason I am unable to get it to work following the specific instructions. Software developers are constantly touting their "Improvements", "Enhancements". Advancing. Not regressing.
In the case of the SDR world. I own a few pieces of "payware" and many more freeware applications.
I'm out. You cannot, with a good stance, say that anything stated is without a doubt plausible.
And to defend the Once Upon a Time in Mexico scene where Depp tasked Trejo with a mission. A Mexi-Can't easily can turn into a Mexi-Can.
