SDR# bandwidth question
mancow
N.E. Kansas
Does anyone know if it's possible to mod the program settings to allow NFM bandwidth filter sizing in excess of 32000?
I have an older instance of the program that allows everything up to 150000 but version 1.0.0.1299 stops at 32000.
I am trying some wide fm FDM demod stuff and I heard the regular broadcast WFM setting adds in some additional filtering. I need the wider bandwidth with nothing filtering it.
rbm
Upstate New York
Edit the SDRSharp.exe.Config file.
Search down to this line:
<add key="minOutputSampleRate" value="32000" />
Change the 32000 to the maximum of your choice.
The software seems to honor what you key in there.
I've set it as high as 93,000.
Such as:
<add key="minOutputSampleRate" value="93000" />
Then I can set it to anything less than 93000. ;)
I typically use 36,000 for NOAA weather satellite APT decoding.
Rich
