sdr# DSDplus plugin - how to save "enable aux audio"?
CaptainNemo
Genoa, Italy
Hi everybody.
Anyone knows ho to save the "check" on "enable aux audio output" from run to run?
I have to set it every time I start sdr#
Currently I use this plugin just to have an aux output to vb-cable, main audio to speaker and aux audio to vb-cable at the same time; if someone knows an other way to do that please, share...
Thanks in advance
gio
thewraith2008
Plug-in does not save that option.
You could just do:
Set the SDR# Audio > Output to your VB cable.
Then right click speaker on systray Sounds > Recording > VB cable > Properties > Listen > "Listen to this device"
This will make sound output to speakers and same audio to VB cable.
