SDR# how to decode DMR
vinyljunky
I run Windows 10 and have an airspy mini with SDR# + Frequency Manager Scanner + Simple DMR. It seems that recently the Simple DMR Plugin has stopped working. So what can I use to to scan and listen to NFM and unencrypted DMR?
AB9NN
Beulah, MI
DSD+ FastLane software will decode many digital modes!
dave3825
rebmeM evitcA
Suffolk County NY
While DsdPlus will decode Dmr as @AB9NN posted, did you update anything in your sdr# directory that may have caused the plug in to stop working? Did the user switch freqs? Did Windows do any updates?
Zentral Europa
I still use SDR # 1910 together with the "Simple DMR" plug-in and an AirSpy mini without any problems.
Has something changed in the settings of SDR#? Which version of SDR# is used, maybe try a slightly older
version to see if "Simple DMR" runs with it?
