sdr# linux madness
geraldw3210
SE Penna.
Hello again. WOW 7am and im already burnt out trying too install? get SDR# up and runing in my linux system. this is nuts (or is it me??) ive been to 4 different sites rnning all kinds of commands installing god knows what and i still dont see SDR# or any way too rn it if it is even installed...
i tried this page last . it looked like a good source Linux Software [rtlsdr.org wiki]. but i dont understand it . most of the commands dont work some i have installed already thru synaptic SW manager but i am no closer too the legendary SDR# sw running on my system. help me. please someone help me.
natedawg1604
Colorado
Wow I didn't know you could run SDR# on Linux.
vince48
Central Valley, CA.
Guys,
Greetings. let me ask a question I have wondered about for a long time. What advantages is it to run SDR# or any other radio program in Linux? Does the program run faster, better or what?
vince48
jwt873
Woodlands, Manitoba
Many people (like myself) use Linux as their primary operating system. As such, you need Linux software to access your SDR hardware.
I tried for a while to get SDR# running on my PCLOS installation. I never had much luck. However, some guy built a Linux distribution around Debian called Skywave Linux. It boots with all the SDR stuff installed and ready. I've used it to access my Nooelec RTL dongle. It works well.
You can boot off the CD, or create a bootable thumb drive, or install it beside your current operating system and boot via GRUB. I've meant to look through the distro and see what they did to make it SDR friendly and then applied that to my PCLOS.
See: --> Skywave Linux
BTJustice
Linux requires you to type a bunch of commands every now and then to make something work.
First you have to get the proper settings in Linux for SDR# to work...
Then extract SDR# to a folder and do the last half of the above link's directions.
To run SDR#, open a Terminal window in the folder where SDRSharp.exe is and type in...
mono SDRSharp.exe
Mono has to be version 4.4 or above.
You need to blacklist your RTL-SDR which I told you in your Linux post a few days ago...
http://forums.radioreference.com/so...software-newer-linux-distros.html#post2609250
SDR# advantages? PLUGINS!!!
mbott
EN80nd
As much as I would prefer to use linux with my SDRplay RSP, the options available using Windows 10 are just too much to ignore. Currently (in preference order) I'm running SDR-Console 2.3 & 3.0, SDRuno, HDSDR and CubicSDR. So, Windows 10 now has two purposes for me: SDR use and taxes. :)
Mike
geraldw3210
SE Penna.
Mike
Well since MS is going too start charging win 10 users $7.00 per month per computer you keep on paying them (for the rest of your life). i will continue too use my opensource free operating system and software.
mbott
EN80nd
And when that happens, I'll be linux-only.
Mike
vince48
Central Valley, CA.
Sir, can you point to a url where you saw that microsoft will charge $7.00/month per computer? I have heard nothing of this.
I and others would be very interested if in deed Microsoft announced this. Thanks in advance for the url.
:confused:
