SDR NFM Help
scottymcneill8657
Huntingtown, Maryland
Hi. I'm trying to trunk an analog system with SDR and am having problems. I'm using a tapped PRO95 for the data channel and an sdr dongle for the voice. I have unitrunker working and it is decoding data fine and following the conversation in SDR#. The problem is I have no sound in NFM mode. Everything else works though.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Probably have your squelch turned on or set too high on the sdr. Make sure the squelch is unchecked. Turn your AF Gain up high also. As well, make sure your volume on the computer is turned up and not on mute. Just a few suggestions.
Sent from my Samsung Galaxy S3 Using Tapatalk 4
