SDR# + Scan - error code
majoco
Stirrer
New Zealand
Hi Guys, request a bit of help here please.
Usual RTL/USB dongle which works fine with SDR# v1132 and 1135. Download and installed the "+scan" plugin - download successful. Added a few local utilities in the same frequency band - hit "Scan" and it comes up with an error which says "Unhandled exception has occurred......Index was outside the bounds of the array" which can be cancelled by the "Continue" button. The same error message come up when I change the demod mode from AM to NFM for instance. Machine is a Dell Inspiron 6400 Laptop running WinXPsp3.
Any clues gratefully received - thanks.
So Far Away....
squeaky wheel theory...
roll back(reverse) any
changes you made to
the SDR# folder..see if
the new files are the cause.
Keep 2 SDR folders,one for
updating/modifying the other
to be sure you have a -clean-
current set up.test changes in
the mod folder.
D
DaveNF2G
Guest
You must stop the SDR dongle before changing any settings, then start it again. That includes settings within plugins. Otherwise it gets confused and throws errors.
majoco
Stirrer
New Zealand
Yes and yes, thanks guys, even went as far as turning off the laptop and starting again. No change. The standard SDR# still works well, I have a second installation for the "scanner".
