SDR Sharp Frequency Scanner & Manager
norubit
Hi,
I have downloaded the latest SDR Sharp Community Package with Plugins. I have created a group inside of the Frequency Manager but how do i get the scanner to scan only frequencies listed in the group and play audio from each one when it has audio?
83558
BM82557
Berkeley Co WV
Click on Edit Scan Ranges, setup the Start and Ending freqs, select the Detector you want to use, the Bandwidth and Step size then click OK. Change from Scan all with save new to Scan only memorized - exclude new then click Scan . See my setup below -
norubit
Thank you for your help. Is there any way to only scan a certain few frequencies instead of a range.
I want to scan only the below:
461.96875 MHz
461.56875 MHz
461.75625 MHz
461.78425 MHz
461.41875 MHz
461.84375 MHz
Also, how do I get it to stay on the channel while audio is playing and then continue scanning when audio has stopped
BM82557
Berkeley Co WV
461.96875 MHz
461.56875 MHz
461.75625 MHz
461.78425 MHz
461.41875 MHz
461.84375 MHz
That's what Scan only memorized - exclude new does
Click on Configure and adjust the settings ,
Expand the above for my replies
here's the manual -
  • Frequency_scanner_plug-in.pdf
thewraith2008
The manual offered above does not really apply to the version of the Frequency Scanner plug-in that is supplied in the 'Community Package'.
You may wish to use the updated Frequency Scanner plug-in that is released here (which the manual does apply)
The plug-in scans a range of frequencies and if the scan mode is 'Scan only memorized - exclude new', it will only stop on active frequencies that are stored in the Frequency Manager. It does this regardless of groupings that the stored frequencies belong too.
Since your scan range is barely 600 Khz, you could just scan that range and lockout anything in between that is active that you not want.
