Anyone use this program? I'm having an issue with the freq. being off. If I type in 129.900 which has activity on it I cant hear anything unless it tune it to 128.600. Any idea why and what I can do to fix it? What filter settings should I have?
You can start out at NFM and 7500 Filter bandwidth and go wider or narrower from there to your liking.that did it thanxs, now for listening to public safety,fd, what should the best filter bandwidth and filter order should it be? what step sizes should i use for air, pd/fire?
I'm getting to that point nowadays - just using 2.5 kHz stepping across all bands - and only find myself needing to change it if I'm trying to grab some NXDN traffic which all happens to be on offset frequencies here in my area (+/- 3.125 kHz from licensed frequencies). As noted by someone else it's probably indicative of the same supplier being used for the hardware I suppose, all I know is it was incredibly frustrating trying to figure it out at first as to why I wasn't getting decent signals and decodes - it's because I was always "off" by just enough to break decoding.2.5 kHz is my default so I don't have to keep constantly changing it from band to band.![]()
