SDR Softwares opinions
Bethanylt241
Bethany WV
I am looking for a good software to run for my state P25 system on a Simulcast cell. I’ve had Fastlane and recently switched to SDR trunk but I can’t seem to work the kinks out for it to work on a simulcast cell. I’ve tried to get OP25 but it is too technical for me to get up and running it seems. Any input on a good software program for Simulcast would be very helpful. Thanks in advance!
maus92
The OP
You have tried the three best out there. Not sure why you are not having success, but it could be your antenna system, SDRs, or computer hardware. Or maybe you are out-of-range of the simulcast cell, or perhaps a nearby cellular telephone site is interfering. SDR Trunk is probably the easiest of the three to set up.
DaveNF2G
Latham, NY
SDRTrunk is not "finished" with respect to non-LTR trunking. There is a constant stream of updates, bug fixes and rebuilds. Best to stick with stable completed programs like DSDPlus/FMP.
CanesFan95
Analog already is interoperable.
FL
Have you tried this for OP25? (Attached.)
  • OP25 Windows 10 Virtual Machine Setup Guide July 10, 2022.zip
WX4JCW
Stow, Ohio
SDR Trunk works best on Simulcast, make sure in the channels switch to set it to LSM also for any solution you will needs an Airspy R2 or multiple RTL-SDR's depending on system size
dave3825
Suffolk County NY
Tell us more about the issues with the simulcast. Usually ppm and gain properly set with a decent antenna will yield really good results. OP25 will also but if your not a Linux guy it can be challenging. Fortunately there are a some good how to guides on the install, and copy/paste will get it up and running.
lostfiringpin
ANNISTON AL
If your still having problems with it let me know and I'll see what I can do to help. It took me a few months of tinkering with my 2 nooelec v5's and SDR-Trunk to get it working.
