SDR Trunk .0.2.0 / 0.3.0 question
dave3825
Suffolk County NY
I listen to a mot type 2 system that has 14 digital talk groups. I use sdrtrunk for the digital part of this system as it works great since the digital only takes place on 4 freqs.
A radio id of 26011 shows as 01A0 in the program when that radio transmits. What is the math to convert 01A0 to 26011? I have most of the Rid's logged as to what agency/department they belong to I want to assign the alias to each radio to know who is who.
GTR8000
NY/NJ Database Guy
BEE00
Sounds like you're seeing the Talkgroup ID, not the Subscriber ID.
1A0 HEX = 416 DEC
For a Type II system, multiply 416 by 16 to get TGID 6656
Does that match up with what you're listening to?
rcummings14
clarksburg wv
So i am probably gonna sound like a dumba$$. I tried to set up sdrtrunk 3.0. I have 2 sdr dongles. i am missing a lot of calls because i think that on of the dongles is not set to the correct ppm. i have noticed in v3.0 that you can only set the ppm for one dongle. is there a way i can set the ppm separately for each dongle. or does it not matter?
BM82557
Berkeley Co WV
Under Tuners click on each to set the PPM -
rcummings14
clarksburg wv
so i tried to what you showed in you screen capture. it will let me click on on dongle to adjust the ppm, but when i click on the other tuners it will not let me make any adjustments
DSheirer
Fulton, NY
Each tuner can have one or more named tuner configurations that remember the PPM, last tuned frequency, gains, etc. The tuner configurations are identified by the tuner type and the tuner's serial number. When you select a tuner in the top window, a list of available tuner configurations appear in the bottom window. This allows you to create several configurations per tuner with different gain settings suited to each situation. Only one tuner configuration can be designated as the default configuration and that's the one that's selected on startup, and/or applied to the currently selected tuner.
As you discovered, if each tuner doesn't have a unique serial number, the application can't identify the correct tuner configuration to use and it will end up using the same default configuration across several tuners.
Denny
