SDR Trunk .0.2.0
cpetraglia
Fairfax, VA
After getting my updates for Win 10- 64bit, the console window at start-up stays blank. It opens and starts the GUI which is working. What would keep that window blank?
DSheirer
Fulton, NY
Chuck, does the dongle still work with other SDR applications? Did you have to reinstall zadig after the Win10 updates?
If you send me the application log (SDRTrunk/logs/application.log) I can help you troubleshoot.
Denny
cpetraglia
Fairfax, VA
Yes I did have to re-install the driver. The program it self still works fine, just a blank window at start up.
And yes it works with SDR Console. It is an Airspy original. I'll look for the logs and send them.
Thanks Denny.
cpetraglia
Fairfax, VA
It did not upload. I always have trouble with the up loads. I'll try again.
I tried a zip file and the raw text file. RR says both are invalid file types.
cpetraglia
Fairfax, VA
Denny,
I found the 0.3.0 was released. The console works fine in the new version and I really like the re-design. Is the new JMBE file required or will it work with the one I am using?
Thanks for a great program.
Chuck
