SDR - USB - cable
millam
Old Radio Guy
If someone has a usb extender cable please try one with the rtl-2832 on the end and see if it will work.
I use a 4 ft one and it works. A 50 ft cable and amp are available on ebay for $13. Before I buy one maybe yall can see if that type would work. I may try to make a 12-15 foot one and stick it on the end of a pole and see what the signal looks like.
Mil
n9mxq
Belvidere IL
I'd think you'd be better of with an outdoor antenna, less waterproofing issues..
I'm sure the dongle wouldn't like a shower...
Comint
Queensland, Australia
Mil
The USB2 Standard states that the maxium length for an extension cable is 5 metres (16 feet).
Comint
jcims
Mil
I've been using an $11 30' repeater cable for at least a month now. I'll be buying more, but there are caveats:
- I've yet to find one that is even remotely built for outdoor use. Long term outdoor installation would require conduits or spares, and weatherproof enclosures for the repeater end and dongle.
- Sometimes they aren't stable. I haven't figured out what it is yet, but some times they will run for days flawlessly, other times they will hang after an hour or two. Unplugging and plugging the cable from the PC always resets it, but that's not always possible.
- The repeater circuitry is at the dongle end and isn't shielded. I added a six foot passive USB extension and snapped a ferrite choke to it. The repeater also has a nice little breakout for the USB power and data lines, making it easy to solder a couple of bypass caps to the power to help reduce electrical noise from the PC.
Overall it's a wonderful way to get the dongle out of the computer area and, as long as it's reliable, passes the information without loss...
Thumbs up from me!
millam
Old Radio Guy
Thanks, jcims, I just wanted to know if it would work. I want to use a different computer and I can't get
the coax there, but I could get a usb extender cable there. No outside runs at all, just curious about the
dongle being up in the air closer to the antenna on the pole idea. The 16 foot limit is without the amp, I
believe.
Mil
datainmotion
Hoi Polloi
Colorado
Wirelessly posted (Clacking rocks together: Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID X2 Build/4.5.1A-DTN-150-30) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
FWIW - there are devices that use ethernet to extend USB to around 150 ft, as well
