SDR
ThePhotoGuy
Maryland
Recently bough an SDR device, RTL2832U. I have been hoping to use this to run Unitrunker instead of wasting a radio to run Unitrunker. Curious if anyone else is using it in Maryland?
I am trying to figure out how to calibrate it also...
Mr_Boh
The Land of Pleasant Living
Yes I am. On the RTL-SDR site there's a pretty good guide for using it with Unitrunker. My recommendation is to start with SDR# and get comfortable with the waterfall display of your local freqs and how you correct for the "drift" that happens.
ThePhotoGuy
Maryland
Thanks, I will have to check it out.
marksmith
Anne Arundel County, MD
I monitor about a dozen sites in Maryland with Unitrunker, but only one dongle, not the voice following two dongle setup.
The key is to get the offset on the dongle determined so you can properly tune the control channels. I use the Sharp application for this, tune in a known control channel, and then play with the offset until it is the clearest. Then I set Unitrunker's receiver for that offset. This results in Unitrunker being properly tuned. You can uncheck the mute selection on the receiver when you set the offset to verify the improvement in tuning. Each dongle is a little different. I have 3 and none are the same.
So, once you fire up Unitrunker, go to the receiver, and set up a receiver for the dongle. Enter the setup, and start the receiver. Once it is running, it should open up a monitor window for that system, populating all the frequencies and starting to show active talkgroups and radio ID's
You can click on either and using the label field, name them wit text descriptions.
536/436/WS1095/HP1/HP2/996T/996XT/996P2/396XT/325P2/PSR800/15X/others
