SdrGlut uses 4 software defined radios to scan 5 different frequency ranges
I thought that some people will find this interesting.
This video shows SdrGlut using 4 software defined radios to scan 5 different frequency ranges.
SdrGlut prebuilt exes for MacOS Sierra, MacOS High Sierra, MacOS Mojave, MacOS Catalina, uBuntu18.04, Windows 7 and Windows 10 can be found at -
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Very interesting project. Is there a list somewhere that shows the SDR's that are supported? Obviously I see SDRPlay, LimeSDR, NetSDR, HackRF, but curious about simple RTL dongles and Airspy devices as well. If I missed a list my apologies.
Thanks for your efforts!
Yes, it does RTL dongles and Airspy devices. The Soapy Website has the complete list. When you start up the program, it lists the devices currently installed - if you want additional devices, you need to install them. Here is the Windows start up list -
Lib Version: v0.8.0-PothosSDR-2020.01.26-vc14-x64
API Version: v0.8.0
ABI Version: v0.8
Install root: C:\Program Files\PothosSDR
Search path: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/airspyhfSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/airspySupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/audioSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/bladeRFSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/HackRFSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/IrisSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/LMS7Support.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/miriSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/netSDRSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/osmosdrSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/PlutoSDRSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/RedPitaya.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/remoteSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/rtlsdrSupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/sdrPlaySupport.dll
Module found: C:\Program Files\PothosSDR/lib/SoapySDR/modules0.8/uhdSupport.dll
